Post by murfeey on Mar 26, 2015 17:47:45 GMT
Ok gents need some advice started my build approx 15 mths ago ,h reg eunos ,118 km,running driving starting car,no knocks smoke etc. Today was the day of start up,few electrical gremlins ,engine had been in my garage ,new clutch etc.on start up noisy lifters,as expected,but remain really noisy,checked the oil all good,removed rocker cover doesn't look like any oil on cams ,lobs etc . Engine sounds like a tractor. When stored engine was turned over periodically . Any thought s or pointers ? murf
Post by gwnwar on Mar 31, 2015 22:33:36 GMT
Murf.. First.. Have you put an mechanical oil pressure gauge to the engine by oil filter.. What other work have you done to engine?? If you removed the head the head gasket will go on 2 ways the wrong way will block the oil passages to head.. Did you leave the plastic cover on the oil filter when you changed it?? Try a different oil filter.. Did you put a turbo on and drill hole for oil return line?? if so might have drilled to far into oil pan and put a hole in the oil pick up tube.. With lifter noise let run then shut down for 15 sec. and restart doing that seems to oil up the lifters..
