Post by iparnell on Jan 29, 2015 11:47:26 GMT
Just wondered if anyone may help with this problem.
When removing fuel pipes from tank and injector rail I never took notice of what way round they go so I'm looking for what outlet on the tank goes to what supply on the fuel rail and what one has the fuel filter in line.
Post by Stiggy on Jan 29, 2015 12:19:17 GMT
the pipe nearest to the centre of the pump top is the pump outlet. It connects to the end of the fuel rail nearest to the aux belt. You will notice a fuel regulator valve at the other end of the rail. This goes back to the tank to the off centre at the fuel pump top plate. If you get it wrong the engine will not start. BE CAREFUL, IF YOU HAVE THEM THE WONG WAY AROUND THE PIPE WILL BE PRESSURISED WITH FUEL.
trident
Improvise, Adapt and Overcome
Post by trident on Jan 29, 2015 12:21:12 GMT
Post by iparnell on Jan 29, 2015 12:50:42 GMT
Thanks.
