Post by Peregrine on Nov 15, 2014 18:59:10 GMT
Hi guys I'm new to the forum but I have been closely following Adams triabusa build. I met Paul at RTR in october and decided i had to have a trike! My dad has agreed to go halfs on it with me so were currently planning and saving before we order next year. I have a couple of questions (I'm sure there will be many more in good time!) Does anyone have the dimensions of the triabusa chassis, a local powder coater can only do items up to a moderate size? how does the electric reverse work? Many thanks
Post by Deleted on Nov 15, 2014 19:11:43 GMT
Hello mate I guess at the moment there's only two people who can give you the dimensions. Me and RTR . I'll try and get measurements tomorrow for you. You could always get RTR to powder coat it before delivery. As for the reverse its bolted to the chassis and you control it with a dash mounted button. Cheers Ads
Post by slugshot on Nov 15, 2014 20:10:06 GMT
The reverse is a car starter motor as adam said, it bolts to the rear left chassis upright. It comes supplied with a gear with an internal thread that replaces the front sprocket nut. The starter motor engages with it when you press the button. For best performance use a battery capable of continuous load, not the bike battery.
Post by Peregrine on Nov 15, 2014 23:16:23 GMT
Thanks Adam, were planning on powder coating the rear swing arm and rear wheel at the same time as the chassis so they're all the same colour . I Suppose I could just send them up to RTR and ask them to do it at the same time for an additional fee.
Slugshot (Kevin?)That's a good point about the battery, i've been looking at a few options - does anyone on here run a Lithium car battery?
Thanks, Al
Post by Deleted on Nov 16, 2014 8:56:50 GMT
I guess it all depends on the colour you are choosing. As long as you have the Ral colour you should be ok. I'll get this dimensions today.
Cheers Ads
Post by slugshot on Nov 16, 2014 11:13:03 GMT
Slugshot (Kevin?)That's a good point about the battery, i've been looking at a few options - does anyone on here run a Lithium car battery? Thanks, Al I use a lithium battery on my tR1ke but not for the reverse.
Post by Deleted on Nov 16, 2014 16:56:50 GMT
Took some measurements today. 1.36m at the widest point 2.5m long 1.1m at the highest point.
Hope this helps.
Ads
Post by Peregrine on Feb 7, 2015 14:53:47 GMT
Ive taken the first step in my trike journey - now the proud owner of a 2007 Hayabusa
Post by Peregrine on Feb 7, 2015 14:56:25 GMT
It's crash damaged but runs fine - as a biker i could'nt quite bring myself to tear apart a perfectly good bike! you'll notice the front wheel is not strait. frame is cracked on the front end, forks bent and fairing damaged.
Post by Deleted on Feb 7, 2015 15:07:11 GMT
Excellent mate nice one. You need to start a build thread. Look forward to seeing the build progress good luck Ads
Post by Peregrine on Feb 7, 2015 16:16:16 GMT
Thanks Adam, I'll hold off starting a build thread for a while - i have a savings account that matures in September that i'll use to buy the kit (unless my Dad gets impatient and decides to lend me my share of the build costs!). Were hoping to make it to the kit car show in May - with a bit of luck and persuasion he might get excited and want to start early :-)
Post by Deleted on Feb 9, 2015 10:51:55 GMT
Pm sent
