Post by murfeey on Oct 31, 2014 17:20:49 GMT
Doing the wiring so far so good,connected battery ,got lights at rear,cranks,no water in it yet!. I
Gents have got 2 wires that have lost the labels on them,can anyone shed any light ,first is black with a yellow stripe ,plastic connector on end ,small and square,second one is red with a green running through with what looks blue squares on it.with a small plastic connector on it. Or can anyone point me the direction to find a wiring diagram in colour for h reg eunos.
Yours frustrated
Murf.
Post by clintavo on Oct 31, 2014 17:40:29 GMT
What year?
trident
Improvise, Adapt and Overcome
Post by trident on Oct 31, 2014 19:09:25 GMT
Post by murfeey on Oct 31, 2014 19:32:01 GMT
Sorry gents its a h reg eunos as trident says 1991 cheers for link.
Murf
Post by snowbird1 on Nov 1, 2014 14:38:03 GMT
The 'meter' fuse powers a number of Black/Yellow circuits there is also a B/Y wire from the airbag fuse, both fuses are powered with the key on. Not sure on the Red/Green - I've seen that colour in the ABS wiring but not with a floating connector. Both connectors may be for optional functions not fitted to the donor.
Post by gwnwar on Nov 2, 2014 20:10:02 GMT
What part of the harness are wires in and if you can post a pic.. My guess would be the backup lamp switch on transmission.
