Post by miatagr on Sept 15, 2014 18:33:17 GMT
After autocrossing the new car yesterday, it appears a wing will help. Especially for the higher speeds of track days. Options... I can get a wing off ebay for $50, The Exo stays $200, (wish I had ordered my frame with the bolt holes). Then modify the wing to fit the wider spacing. A search showed that COT wings are still available for $400-$500. They say they are the show wings but I think I saw on here that those still work. Get the Exo stays and it should be a bolt in. Buy the new wing and stays from Exo for $1000 but there is a question in my mind. Most of the builds I see on here appear to be drivers and show cars.... The new Exo wing is beautiful and makes me wonder if it was designed for looks or or to work as well as the other two options? This makes me reluctant to buy it without more info... Looking for responses from other track day/autocrossers....
Post by Stiggy on Sept 15, 2014 20:03:34 GMT
Perhaps we should consider the down force required, front/rear? How much drag are we prepared to accept? Is it a time to ensure tyres/suspension (corner weights) settings are perfect for the track in question? Wings do look great but we should consider all other criteria that could effect handling too.
Post by Kevin Patrick on Sept 17, 2014 21:51:28 GMT
Post by tomaff on Sept 18, 2014 16:47:42 GMT
Delivery to the UK?
Post by miatagr on Sept 19, 2014 13:38:45 GMT
Wow... Thanks Kevin for answering many questions for the engineers. I was about to ask about mounting heights before I drill holes in my support bars. Looking at where others have mounted their wings, it seems to me that the top of the seats and roll bar are in the air flow in front of the roll bar, reducing it's efficiency... As a self taught dirtball mechanic with no engineering background, is this true?.. Would mounting the wing higher than the roll bar be better?
Warren van Nus
Junior
Post by Warren van Nus on Sept 19, 2014 14:25:36 GMT
The wing would indeed work a little better if it was above the rollbar, but it would need to be at least 5 inches clear before you're in "clean" air. Unfortunately that looks ridiculous and raises the CG significantly, and we have to cater to those customers that buy a wing for aesthetics as well as performance. Based on the quick CFD I did and general aerodynamic theory, you're better off placing turbulent air on the high pressure side of a wing rather than the bottom. The flow underneath is more important and harder to control. The horizontal cross sections of the seats and diagonals are much smaller than the tube, so the current position is a lesser-of-two-evils thing.
All this goes out the window with experimental data, though. If you'd like, you could rig up your own mounts out of sturdy rollbar clamps and slide them up and down. Here's a good experimental setup: tape some string to the bottom of the wing, and aim a GoPro at the strings and a phone with a GPS app showing speed. Whatever position has the strings staying laminar at the highest speed is likely the best performing one.
Post by miatagr on Sept 21, 2014 1:04:59 GMT
Thank you Warren
Post by miatagr on Sept 21, 2014 1:08:18 GMT
Thank you Warren
