Post by jimmypatch on Sept 15, 2014 20:39:03 GMT
So that was an emotional evening, the body is now off and ready to be scrapped. The thing that was "snagging" was the last bolt from the sub frame, which I left in to keep the body steady while I did some other jobs, like an idiot I forgot I left it in!!! Also the steering column was an issue.
Post by jimmypatch on Sept 16, 2014 18:12:12 GMT
The bonnet badge is not a David Brown design but it's pretty all the same, I got the stickers from isaydingdong
Post by jimmypatch on Sept 17, 2014 16:28:12 GMT
Post by R2S on Sept 17, 2014 17:14:03 GMT
I purchased seat heaters from Rimmers and Interiorsseating charged me £20 to fit them as part of the seat build.
Post by jimmypatch on Sept 18, 2014 10:11:35 GMT
Seat heaters would be nice, but I cant justify them.
Post by R2S on Sept 18, 2014 11:05:01 GMT
Plan to use the car throughout the year so some form of heating was a a must.
Post by snowbird1 on Sept 19, 2014 6:00:38 GMT
I have always treated open cars a motorcycles and your feet don't get as cold and wet (until it fills with water and you hit the brakes!). Spend the money on some good weather gear - motorcycle or ski clothes. I still have my dry suit but admit I only put it one when I'm using the pressure washer. Back in the day I remember wiping snow off the seat before driving, total wimp these days and head off to Arizona when it starts to get chilly!
Post by jimmypatch on Sept 19, 2014 8:59:31 GMT
I was thinking Irvin flying jacket and goggles
Post by gwnwar on Sept 19, 2014 20:26:58 GMT
Post by jimmypatch on Sept 19, 2014 21:45:32 GMT
That would add weight
Post by gwnwar on Sept 19, 2014 21:49:54 GMT
Yes but not much.. also add some comfort when cold out to keep other half warm..
Post by R2S on Sept 19, 2014 21:53:19 GMT
Have to confess I'm still thinking about a heater. I am sure snowbird1 mentioned something about water flow being buxxered up if you mess with the heater flow and return (John?). Whatever (if anything) I put in will be very simply and to the feet, for some reason (probably age) even in an ordinary car I get cold feet, and will be either on or off negating any dash board controls (wouldn't want to mess things up.
Post by gwnwar on Sept 20, 2014 0:37:03 GMT
R2S.. You got me there what is "buxxered up".. You can put heater in line same as OEM was..Back of head is supply and return goes forward to water pump down the exhaust side of engine.. If you don't want hot water flowing in car in the summer time you would need a valve to shut it off to the heater core and divert it to the return line. You have to have flow always from back of head to return to water pump..
Post by snowbird1 on Sept 20, 2014 6:39:41 GMT
Have to confess I'm still thinking about a heater. I am sure snowbird1 mentioned something about water flow being buxxered up if you mess with the heater flow and return (John?). Whatever (if anything) I put in will be very simply and to the feet, for some reason (probably age) even in an ordinary car I get cold feet, and will be either on or off negating any dash board controls (wouldn't want to mess things up. I was looking at blanking off the OE heater connections but realized that coolant from the rear of the head is needed to ensure adequate cooling for #4 cylinder and for the coolant gauge to work properly as the temp gauge sensor is on the rear outlet. I'm thinking of using the heater core as an auxiliary radiator if needed but of course could be used as a heater.
Post by jimmypatch on Sept 20, 2014 9:07:55 GMT
Just got off the phone to Mota-Lita they are going to make me the correct original wheel and they will custom make me an Aston Martin boss with an MX5 spline, very tasty
