Post by Paul (madeye) on Aug 16, 2014 9:15:39 GMT
I initially assumed that if I ordered the accelerator pedal from RTR it would be a good fit and should work well with the Willwood pedal box they supplied. This was a wrong assumption. The pedal is not what I would have expected and looks really naff when put alongside the others. A bit of a disappointment. So I have done as most others have and made contact with The Joker. A new Pedal has now been ordered and I should have this by the end of the week. why are you surprised about receiving a naff product from RTR? its seeming to become the norm now.. Any readers including mods take that as you will..
Post by rossco on Aug 16, 2014 12:49:10 GMT
Hi, Just been reading your build thread and found you are in exactly the same position as I am. Good to follow all the same problems I too have encountered. I have also ordered the pedal and shifter from Joker as you say the RTR part is not that great.
If you have a look at my build you'll see I have also opted for the enclosed front floor. I have also enclosed the rear. whether or not it gets used is another thing......
Looking good so far.
I will follow your build and hopefully be able to pinch a few tips along the way.
Regards Ross
Post by kingofthetwisties on Aug 16, 2014 13:52:05 GMT
Hi Ross
Good to hear from you. I'll take a look at your build thread later when I get the chance. It will be good to have someone to bounce ideas etc off.
Where are you based?
Anton
Post by rossco on Aug 19, 2014 10:16:46 GMT
Hi Anton,
Based in Rugby,Warwickshire.
Making good progress. Just templated the bulk head and fitted the pedal box and about to fit the steering column bearing. (pics to follow) Ross
Post by rossco on Aug 19, 2014 10:41:04 GMT
Meant to ask you if when you fitted the pedal assy that the front needed to be a few mm lower than the rear of the assy to allow it to line up with the bulkhead correctly?
Post by kingofthetwisties on Aug 19, 2014 18:40:21 GMT
Hi Ross
I didn't set mine lower at the front. I used a spacer to lower the unit to give clearance but I used the same size spacer front and rear. Not sure if ill have problems at a later stage and have to change this
Post by kingofthetwisties on Aug 20, 2014 10:29:09 GMT
Look what has arrived today That will look so much better
Post by ridgeback on Aug 20, 2014 11:24:55 GMT
More goodies heading your way, should be with you Friday.Postage on them was ridiculous.
Post by kingofthetwisties on Aug 20, 2014 11:51:14 GMT
Thanks
Hope to have a rolling chassis after this weekend so they will be just in time
Post by bingo on Aug 20, 2014 13:32:27 GMT
Probably going for a blast later u in this evening??
Sent from my SM-N9005 using proboards
Post by kingofthetwisties on Aug 20, 2014 21:09:03 GMT
Hi Bingo sorry been offline all night. Would have been in. Sorry I missed you.
Ill pm you my contact details for next time
Sent from my iPhone using Tapatalk
Post by rossco on Aug 21, 2014 17:08:17 GMT
Where did you get that lovely pedal from?
Post by kingofthetwisties on Aug 21, 2014 19:57:21 GMT
Where did you get that lovely pedal from? It's from the Joker If you go into items for sale he has a post in there advertising them Sent from my iPad using Tapatalk
Ricco
Junior
Bought, not built.
Post by Ricco on Aug 21, 2014 20:13:45 GMT
Whereabouts in Lincs are you? I'm in North Somercotes
Post by kingofthetwisties on Aug 21, 2014 20:21:19 GMT
I'm from Wootton in North Lincolnshire up near the Humber Bridge.
North Somercotes? Is that Nottingham way?
