Post by seabee70 on Oct 14, 2014 19:33:01 GMT
Hi Derrick,, I sourced brake fittings from these guys,http://www.ormebrothers.com/ Hope this helps.
Post by slugshot on Oct 14, 2014 20:55:33 GMT
Ian, Glad I won't be the only one. How are you going tunnel less? Are you mounting your radiator out back, or route tubes to the sides? You must be going Klicktronic. Do you have any pictures of your progress, ideas I might steal? ? Thanks, Derrick Derrick, I don't know if you've looked at Andy7b's thread he was the first to go tunnel less, he still uses the old fashioned gear stick were the tunnel would be and it still looks great. I modified mine to have only the cables,hoses and wires going along were the tunnel would be to the front all in a 2in tube. I had to abandon the idea of having the rad at the rear as it wouldn't stay cool at low speed, so I now have the 2 main coolant hoses running along the centre below the 2in tube. I also blanked off the 3 smaller hose fittings to the rad including the water cooled oil cooler hose.
Post by 4sfed on Oct 17, 2014 19:21:30 GMT
Do the tubes get screaming hot? I was going to insulate them in the tunnel. I'm hoping to elevate my tunnel on unistrut for air flow.
Post by andy7b on Oct 17, 2014 21:11:51 GMT
The water tubes run at pretty much water temp so high 80-90 deg C but I wouldn't think they need any insulation. Tunnel less is a good way to keep things simple, and like Slugshot says you can blank off the 3 smaller pipes (2 bleeds and one for the heat exchanger on the oil side) so all your left with are the 2 main water feed and return pipes. You can T the heat exchanger into the water feed pipe.
Andy
Post by 4sfed on Oct 18, 2014 1:50:55 GMT
Hi Derrick,, I sourced brake fittings from these guys,http://www.ormebrothers.com/ Hope this helps. Hi Val, I got the brakes sorted out here locally.
Post by 4sfed on Oct 18, 2014 1:55:59 GMT
Post by 4sfed on Oct 18, 2014 1:57:08 GMT
I tried moving the spoiler closer to the cabin. What do you think? Be honest. Derrick
Post by slugshot on Oct 18, 2014 8:11:25 GMT
A bit hard to say really, i'll not say what I think until its a bit more complete. It might look better than stuck way back up top as the other attempts iv'e seen. Personally I don't see the point in having a great big wing way above the CofG...I would fit it to that little golf cart instead
Post by mawdo81 on Oct 18, 2014 11:05:09 GMT
What's the wing for? Style or rear downforce? If the latter then on a trike, surely the rear wheel is the weakest grip point so wouldn't it make more sense fixing the wing to the swingarm?
Post by 4sfed on Oct 18, 2014 13:37:35 GMT
Kevin, look closer the golf cart already has one. Just kidding, I had seen others put the wing way out back and in my humble oppinion it looked lonely out there on its own. I was thinking of setting my tail lights up on the brackets for better visability of the drivers behind me. The extra bracketry might come in handy for attaching other things. Remember the cars and trucks here in the US are big and the rednecks take the truck thing to a new level, I should be able to drive right under some of them. There is a guy in my neiborhood that has a truck my wifes car could fit under never mind mine. I also have the canard wings for the front which are probably just as usless, but the car seems so light any down force must be better than none. I think its more the look, I like it equaly with or without the extra plastic for now its mounted with double sided tape just to get the feel for it. Trust me if the spoiler or wings start whistling at speed they are going in the trash. I picked up a bunch of hoses. Hopefully I can get this thing running soon. Spoiler was side thing while waiting on parts. Derrick
Post by 4sfed on Oct 18, 2014 14:26:48 GMT
Mawdo81, I'm not sure if the spoiler has any practicle use. I think it's more for looks, just like the canard wings. I'm sure they create some down force, but I'm not taking the car to a wind tunnel just to get the #'s. The only time I figure you would have enough speed to make the wings work your already at speed, and when you need them for sticktion you've slowed down making them usless. Like I said, I'm using them for light mounts and I like the look as long as they are quiet. I thought the same thing about a wing over the tire, but if you think it looks silly where I have it try it strapped to brackets out there. I figured at the widest point and it will still force the wheel down. I may need a stronger spring or progressive. derrick
Post by seabee70 on Oct 23, 2014 0:02:44 GMT
I'm sure you'll find the oem spring too soft & a progressive wound spring is a good choice.
Post by 4sfed on Oct 25, 2014 2:51:05 GMT
Val, Did you change your spring? If so what did you go with? Thanks for the advice about the brakes. I meant to sound more thankful at the time, but when I read my own writing it sounded short. Any help you can give is always welcome. I may try to start the beast this weekend I'll make no promises. I have no idea how long this motor has been sitting. I pulled the plugs and dropped in some mystery oil to sit overnight. If this Frankenstein starts it will be a testiment to Japanees engineering. The motor was a backup for a turbo bike While the turbo motor was at a machine shop. I'm hoping to use it in the same capacity till my supercharged motor gets rebuilt. It is now running FZ1 fuel injection, ecu, cooling system, charging system and clutch, it all installed into the right places. I'll be welding up the exhaust this weekend because the FZ1 and the R1 have different oil pans and the pipe doesn't clear.
Thanks again,
Derrick
Post by paulh on Oct 25, 2014 8:49:27 GMT
Hi Derrick, I think spring choice also depends on which swing arm you have. the length changed on each model of R1. My 2007 is around 5inches longer than the early ones, and I am running an 800lb car spring on the r1 rear shock. With the standard spring the chassis was touching the floor when I got in it
Post by 4sfed on Oct 25, 2014 16:32:05 GMT
Paul, Thanks, which car did you get the spring from? Was it available in the US? I never thought of using a car spring. All the bike spring people want so much for their products. They know we are a captive audience, till someone like you breaks out of the box and finds an alternative. Honestly I have both 04-06 and a 07-08 swingarm I think I'll use the 04-06 because I have all the pieces for that one. My idea of using the FZ1 didn't work out as well as I thought it would. The swing arm was 50mm to big at the mounting point. If it had been like 10mm I would have gone at it with a grinder, but 50mm. I welcome any input you have. I have scouered your build for tips, but sometimes it's still hard to get the full picture. Thanks, Derrick
