Post by marmot0 on Nov 6, 2014 19:34:51 GMT
Post by marmot0 on Nov 10, 2014 20:18:43 GMT
Hi, first of many silly IVA questions before the test on Friday: I have a fog light switch and a separate tell tail warning lamp, does the switch also need to illuminate?
Thanks
Post by spudman on Nov 10, 2014 21:23:39 GMT
Howdy, my reading of the rules is that you need a tell tale, but it doesn't need to be the switch itself, I'm planning on a separate light from the switch myself so please me know if I'm wrong! Will be thinking of you on Friday for the test, and again on Saturday for your first outing (I hope).
Good luck, Spud
Post by marmot0 on Nov 10, 2014 21:51:34 GMT
If only the dvla was that quick cheers
Post by marmot0 on Nov 11, 2014 11:25:21 GMT
Iva question 2: My brake fluid cap is embossed with dot3 brake fluid rather than dot4 is this ok ?
Post by Stiggy on Nov 11, 2014 19:50:14 GMT
The cap confirms the type of fluid you HAVE used to stop anyone mixing different fluid. IVA is not an issue here they don't ask you to prove what fluid you have used.
Post by Stiggy on Nov 11, 2014 19:53:57 GMT
The fog switch needs to be marked as to it's function with the appropriate decal. It does not need to light up if you have a separate tell tale light
Post by marmot0 on Nov 11, 2014 20:34:07 GMT
Thanks Stuart, all in order then
Post by marmot0 on Nov 14, 2014 14:05:52 GMT
Very easy pass at gillingham will write up a few points later on. Cheers
Post by R2S on Nov 14, 2014 15:08:55 GMT
Brilliant well done, look forward to reading about the experience.
Post by marmot0 on Nov 14, 2014 17:23:52 GMT
Hi, well not too much to report really but a few things that very nearly caught me out, I had not checked the minimum height of the rear lights with a full tank of fuel, luckily I have adjustable shocks but these are shorter than the Mazda originals already so only just scrapped through there. The were not to keen on my wrap around harnesses so if you get a roll bar make sure you specify bolt ins, I very nearly failed here. And lastly an easy one the handbrake mech is all exempt apart from the top surface so a bit of trim needed. The examiner was very impressed with the strength and quality of the chassis and the car was getting a lot of interest, very happy and now looking forward to enjoying getting it in period trim. Cheers
Post by R2S on Nov 14, 2014 19:39:15 GMT
Sounds like my idea to use a BMW Mini combined fog reversing light (orange segment shape; fog in centre reversing light each side of fog) under the number plate is a non starter then.
Post by marmot0 on Nov 15, 2014 7:03:13 GMT
Hi, if you could raise the car up high enough so that the bottom of the light was 35cm of the floor it would
Post by R2S on Nov 15, 2014 12:43:10 GMT
I have fully adjustable suspension so that may be an option.
Post by spudman on Nov 16, 2014 14:47:45 GMT
Well done on the pass, and very reassuring for the rest of us, hope I'll be able to describe mine as easy too.
