Post by fasteddys on Jan 15, 2014 23:50:09 GMT
Post by mrjingles705 on Jan 16, 2014 1:17:30 GMT
Welcome! Hopefully your progress will be a little more rapid than mine
Post by kiwicanfly on Jan 16, 2014 4:53:50 GMT
I'm expecting the build to be ............. Fast Eddy
Post by mrjingles705 on Jan 16, 2014 6:42:04 GMT
Post by fasteddys on Jan 17, 2014 12:08:43 GMT
Going to prep and prime the chassis asap with zinc phosphate primer, then get the subframes and some other bits blasted and painted.
Eddy
Post by fasteddys on Jan 25, 2014 23:29:23 GMT
I started work on it with a free day I had this week. Some of the brackets will not be used so they came off and the chassis was deburred, degreased, sanded and degreased again. Then it was painted with 2 coats of industrial grade zinc phosphate primer The chassis will now go to one side while I get the subframes etc blasted and primed Eddy
Post by fasteddys on May 20, 2014 21:56:16 GMT
Been really busy with work and moving home, but some progress on the kit car Chassis painted and floor on Subframes sandblasted More progress planned soon as this needs to be finished soon. Eddy
Post by freshp5 on May 21, 2014 15:29:22 GMT
Your doing well look good
Post by fasteddys on Jun 13, 2014 23:34:00 GMT
More good progress Subframes painted I have also had lots of other bits sandblasted and I primed and topcoated them. Diff, driveshafts, prop, arb's, topmounts etc. Also been collecting lots of bits Superflex arb bushes KYB Adjustable shocks and jamex springs New crank seal & cas seal, lightened flywheel, new 3 piece clutch and spigot bearing Superflex diff mount bushes on lsd diff Superflex rear arb bushes and more KYB shocks with lowered springs So, the assembly can begin at last Eddy
Post by mrjingles705 on Jun 14, 2014 13:18:49 GMT
Very nice
Post by fasteddys on Jul 1, 2014 22:13:43 GMT
Vast progress has been made as all the bits were clogging the place up. Put the engine in the front subframe. Note the hose clips on the heater bypass pipe Lightened flywheel, new spigot bearing and clutch on Gearbox on Rear diff and driveshafts in the rear subframe with the poly mounts, then connected the front and rear subframes with what is called the power plant frame Propshaft and steering rack on making a rolling chassis as such. More very soon
Post by mrjingles705 on Jul 1, 2014 22:19:00 GMT
4 spairs.... nice
Post by gwnwar on Jul 2, 2014 3:18:55 GMT
remember before you drop the frame on to loosen(just a little) the 3 bolts on the front of the PPF to the trans so you can move the 2 sub frames a little..
Post by fasteddys on Jul 2, 2014 15:36:39 GMT
4 spairs.... nice Got 2 more lol Eddy
Post by fasteddys on Jul 2, 2014 15:40:54 GMT
remember before you drop the frame on to loosen(just a little) the 3 bolts on the front of the PPF to the trans so you can move the 2 sub frames a little.. Yes mate know that. In fact, more progress already. All bolted up with suspension, steering rack etc Eddy
