Hello
Nov 4, 2013 18:56:36 GMT
Post by mattyboy on Nov 4, 2013 18:56:36 GMT
Hello my name is Matt & I want a TR1KE !!!! Lol
Hello
Nov 4, 2013 20:05:06 GMT
Post by edwinwl on Nov 4, 2013 20:05:06 GMT
Make your own. Mine is not for sale...
Hello
Nov 4, 2013 20:12:01 GMT
Post by wonderbadger on Nov 4, 2013 20:12:01 GMT
Is this like an AA meeting? Hello, my name is Andy and I have been tR1ke free for 45 days since Total Kitcar Live and I have cravings
Hello
Nov 4, 2013 21:51:56 GMT
Post by media116 on Nov 4, 2013 21:51:56 GMT
Hello, my name is Chris and I've got a TR1ke that's nearly ready to hit the road...can't wait!
Hello
Nov 4, 2013 22:01:48 GMT
Post by slugshot on Nov 4, 2013 22:01:48 GMT
Well done Matt They say that actually talking about your craving is the first step to recovery. The next step is to ring RTR and order a kit, its an easy cure
Hello
Nov 5, 2013 4:51:19 GMT
Post by mattyboy on Nov 5, 2013 4:51:19 GMT
Thanks all for the greetings & advise.... I feel much better for sharing.
Slugshot-do I tell my wife or just order??? Your Tr1ke is very nice by the way, I have watched some of your footage on YouTube. Strangely my best female friend says "just order".
I am 6ft 2 and well fed (approx 20 stone).... I try my hardest to avoid a healthy lifestyle, so would rather not diet whilst building a Tr1ke. Do you think I would fit? I am in Swindon so RTR is a long way to go for a sit in.
I am looking for a cheap good R1. Is yours 170 hp or 150hp? Does it make much difference.
Hello
Nov 5, 2013 9:45:09 GMT
Post by paulh on Nov 5, 2013 9:45:09 GMT
Hi Matt Im only just down the road from you in Bristol. You are welcome to come down and have a trial fit in mine, although I think you will fit Just fine. I`m 18/19 stone and just over 6 footand with standard rather than sports seats, I can drive in comfort for hours.
Hello
Nov 5, 2013 12:34:09 GMT
Post by edwinwl on Nov 5, 2013 12:34:09 GMT
I am 6ft 2 and well fed (approx 20 stone).... I try my hardest to avoid a healthy lifestyle, so would rather not diet whilst building a Tr1ke. Do you think I would fit? I am in Swindon so RTR is a long way to go for a sit in. If the Americans can fit the tR1ke, you should fit the tR1ke as well.
Post by Deleted on Nov 5, 2013 12:49:57 GMT
Hi Matt, my trike is running a 150 bhp stock engine and produces more than enough power for me. I'm 5ft 8 and a Lardy 15 stone. The first move is to get a test ride out in someone's trike local to you, worst time of year fir most as they will be having winter mods underway. It's not for everyone, but if you want a vehicle more fun to drive than a car, more comfort than a bike and want to stand out, then phone RTR and place that order.
Sent from my ST21i using proboards
Hello
Nov 5, 2013 18:35:26 GMT
Post by mattyboy on Nov 5, 2013 18:35:26 GMT
Hi Matt Im only just down the road from you in Bristol. You are welcome to come down and have a trial fit in mine, although I think you will fit Just fine. I`m 18/19 stone and just over 6 footand with standard rather than sports seats, I can drive in comfort for hours. Hi Paul, I am from Brizzle and have a lot of family there. I may take you up on your offer when I am about some time. My lot are around Hambrook/Frenchay area, they may be nearby even.
Hello
Nov 5, 2013 22:36:00 GMT
Post by slugshot on Nov 5, 2013 22:36:00 GMT
Thanks all for the greetings & advise.... I feel much better for sharing. Slugshot-do I tell my wife or just order??? Your Tr1ke is very nice by the way, I have watched some of your footage on YouTube. Strangely my best female friend says "just order". I am 6ft 2 and well fed (approx 20 stone).... I try my hardest to avoid a healthy lifestyle, so would rather not diet whilst building a Tr1ke. Do you think I would fit? I am in Swindon so RTR is a long way to go for a sit in. I am looking for a cheap good R1. Is yours 170 hp or 150hp? Does it make much difference. I would go ahead and order, if money is tight go for the pre 2001 carb model but either way you will not be short changed on the grin factor scale. My tR1ke is based on the early r1 and its quick enough. As for you fitting the tR1ke, Im 5"7 so I had the chassis seat rails fitted 6in further forward than std so I could reach the peddles. If you look at the pic's of mine you can see the big gap behind the seats.
Hello
Nov 6, 2013 0:00:28 GMT
Post by mattyboy on Nov 6, 2013 0:00:28 GMT
OK I have noticed in some of the build threads that people do not go for factory powder coating. The two I have been reading both mocked up sent to paint shop and then completed final build on return.Is there a reason for this. Factory Powder coating seems more convenient to me. Also do the later engines have different mounts or is it just the swing arms that mount differently. In other words if I built with carb engine initially could i swap to later injection engine later on.
Thanks
Matt
Post by biggunz on Nov 6, 2013 8:09:28 GMT
Not a tR1ke builder but with regards the powder coating, I got my Exocet chassis powder coated from MEV and am having to be so carful not to scratch or chip it during the build! It is easier because there's no need to strip it down, as long as you don't take any chunks out of the powder!
Shaun
Hello
Nov 6, 2013 10:10:22 GMT
Post by paulh on Nov 6, 2013 10:10:22 GMT
Hi Matt. If you have faminly in Frenchay that is pretty close to me. Im in Staple Hill High Street, so anytime you`re in the area feel free to call in for a look. I`m fairly sure the engine mounts are different for each model r1 as you have to specify which one you are using when ordering the kit. Also the wiring would be completely different for carb or injected versions. . As for powder coat , I suppose it depends on if you want to do the build twice, or do it once and take extra care. I bought some cheap pipe lagging to cover most of mine during the build, and because I went for satin black any marks were quite easy to make good
