Post by drbrian on Oct 13, 2013 13:58:33 GMT
This is my build of the Sonic 7 in Texas USA
Post by drbrian on Oct 13, 2013 14:00:43 GMT
Hello Everyone I am glad to announce that Pete Dove dropped off my sonic 7 yesterday, who by the way is a very nice guy. I was ecstatic to have another kit car builder (MEV rocket) dropped off 2 miles away (David Gipson), I am sure we will be annoying each other. I will post some pictures in a bit.
Post by drbrian on Oct 14, 2013 17:47:13 GMT
Ok here is a tip, Buy one of these electric metal shears they cut through the aluminum like butter!! I cant wait to get the floor pan on the car. Here is a picture of my engine. Thanks Brian
Post by drbrian on Oct 14, 2013 17:48:03 GMT
I am missing the assembly manual does anyone have copy they can send me Brian.Glassman@gmail.com I was thinking of doing the floor pan first. Thanks Brian
Post by airforceone on Oct 14, 2013 20:31:57 GMT
It's in the technical section, the very first topic.
Post by drbrian on Oct 15, 2013 1:44:07 GMT
Thanks I also plan to finish the interior, really nice with molded interior covered in leather.
Post by dgibson on Oct 27, 2013 1:15:50 GMT
Just drop the moderator a private message (PM) and he will send you the password for the documentation section. Cheers
Post by drbrian on Nov 3, 2013 2:45:23 GMT
I am having trouble with my Arms bushings. After pressing in the metal crush tubes in to the rubber bushing and the A-arms I realized they were too long for the bushing and won't fit in the frame? . See the following pictures. Are they supposed to come cut to length or do I have to machine down every one : ( which would be a lot of work? Advices from anyone please? Also I am building a bit blind as I don't have access to the build instructions as of yet
Post by pjku79 on Nov 8, 2013 15:33:34 GMT
Brian, great to hear another is being built in TX. What part are you? I have been eying a sonic 7. I am in San Antonio.
Post by drbrian on Jan 19, 2014 5:17:25 GMT
I am in Houston Texas (Sugar Land) I am working on the front suspension now, see the pictures. I had to drill the top shock holes bigger as they were missized. Bend the tabs out slightly. The tricky part was the bushing but I got them to move very smoothly by drilling out the plastic with a 3/4" drill bit and greasing them. I also polished the metal crush tubes by attaching them to my drill and go over them with 1200 wet sand paper. The result is the suspension is very smooth and tight.
Post by drbrian on Jan 20, 2014 0:37:42 GMT
Me and the bulldog, drilling out the bushing. A wiring diagram for the ford focus steering wheel.
Post by drbrian on Jan 22, 2014 2:21:00 GMT
Well I screwed up the firewall so I will re-bend a piece of sheet metal, This time I am going to put a stand off on the firewall so the back behind the seat is not hot to the touch, Basically two sheet of metal with a air gap in-between, this will reduce the noise from the engine too (Maybe).
That is not me in the video!!!
Post by airforceone on Jan 22, 2014 6:44:10 GMT
Trust me you won't reduce any noise from the engine, it's sitting 12 inches away from your head and it sound great.
Post by drbrian on Jan 23, 2014 1:24:17 GMT
Post by mawdo81 on Jan 23, 2014 8:11:50 GMT
Is heat an issue? My concern with heat in the cabin is not enough!
