Post by edvb on Apr 4, 2013 1:31:31 GMT
Thanks Jimmy! I looked at what you are doing and hope I can do as well. I think we are going to have some nice machines when we get done. I can't wait to see what you dream of next.
Post by edvb on Apr 9, 2013 1:23:36 GMT
I got my new fenders in today. The other fiberglass ones just did not have the right diameter and were 6" wide not 5.5" like I was told. Here are the new 5" wide ones before cutting to size and fitting them. What do you think?
Post by edvb on Apr 9, 2013 1:44:20 GMT
Post by roger32849 on Apr 9, 2013 10:36:23 GMT
Ed:
All good stuff there. Those fenders look mighty spiffy. The guy had his stuff together that rolled them. It looks like you have the rear length set perfect. The front trimming will really showcase the front wheels. I wasn't quite sure what I was looking at on the last picture. (Inside the tank??) The fuel tank doesn't have to be pretty, just hold gas...ha! 8-)Will be waiting for the big unveiling. The direction you have taken with the build, I have no doubt the tank will be a work of art. (PM sent too)
Roger
Post by Kevin Patrick on Apr 9, 2013 15:33:58 GMT
Love those fenders Ed!
Post by edvb on Apr 9, 2013 23:57:07 GMT
Thanks Kevin , Jimmy and Rodger.
Between Jimmy, Kevin, Scott and Rodger I could not be where I am at at this build.
I am most grateful for all the information and help you all have given me.
The talent that all of you possess is like Alfred Neuman's Spy vs Spy. Just when you have it all figured out the other guy just blows you away with a new and most clever idea that blows your idea right out of the water!
This has been a great forum to share ideas and Talent and I thank you all.
Kevin, can you send me the angle that is cut on the front of the fender on the Exocet as I might copy those.
Rodger, Thanks for the tip on the seat cover. I ordered one today.
Scott, Thanks for taking care of me! I may screw up a little but I am glad you can bail me out when needed. Hard to believe you are on the other side of the pond.
Jimmy, What can I say. thanks for your wisdom and bending an ear when needed. You are a true craftsman that hides behind modesty. Your help is greatly appreciated.
Some mod's needed to be made to the tank to clear the rear fender but the design is done and I should have the finished product by late next week.
Thanks all
Post by edvb on Apr 12, 2013 1:19:00 GMT
Well I finally finished my wiring loom. Man that is a lot of work but should work well.
Post by edvb on Apr 12, 2013 22:29:45 GMT
Well it is kind of looking like a trike. Test fitting the exhaust and checking tank for final welding and modifications.
Post by roger32849 on Apr 13, 2013 1:06:27 GMT
If no one has committed on it, allow me!! That elevated table you built looks industrial strength and sturdy. What are the dimensions?? As for the loom, it looks like you re-engineered it!! What did you do with the tip-over sensor plug? Did you eliminate it, or keep it?? I am planning to keep mine in the wiring loom..... Just in case I tip over. It all looks good.
I can see the bottom of the tank and where you have to trim for the rear fender. As long as it holds gas, it works..LOL ..everyone is doing a great job.
I spoke to Kevin today. He tells me another guy in Texas is about to order an Eco-Exo. Hopefully he will make an appearance on the forum as well. Ed, I appreciate all the good comments and look forward to doing my own build soon. Roger
Post by edvb on Apr 13, 2013 21:07:31 GMT
Rodger
It is 28" wide x 96" long x 32" high
Tip-over sensor plug and sensor attached and still in same location.
I will E-mail you some detailed pictures on the front end so everything will be clear when you need to assemble yours.
All my fasteners are being changed out to all Stainless or Yellow Zinc grade 8 where needed.
Some of my bolts were a little long so that was addressed as well.
I will send you a the list of correct length, thread size and material type if you like.
Post by edvb on Apr 14, 2013 0:21:20 GMT
OK everyone I need some help on the fenders and side cases I am thinking of installing. First the fenders. I am thinking of cutting them at an angle in the front. How does the length look in the front and back? Angled or straight in front? For the side cases I am thinking of getting these with this mild steel EVO side carrier loop welded on the side of the frame in the location of the case shown in the picture above. Givi V35 Or this one Givi E41. I am starting to lean on this one as it is more retro,thinner and the LED light intergrates better. It is also larger and has a top access for everyday use. It is about 1.5" taller though. What are your thoughts on this?
Post by Scott on Apr 14, 2013 8:04:29 GMT
Looking good Ed, I would give the fenders a angle to give them a bit of shape, just another thought It might be worth getting a mold taken from them as they look great, be good to have the option on GRP ones too, do these need bracing due to the length do they wobble??
The side cases are ok, but narrow ones would be a lot better, Or the bag style panniers hanging on the side rails could be a more flexible option??
Keep up the good work,,
Post by edvb on Apr 14, 2013 14:40:28 GMT
Thanks Scott I thought the angled also looked a little better but I wanted to get as much input before cutting them. I plan to have a lower stay made that will go to the plate underneath the caliper. Here is one more option for the side cases. What do you think of this one? I like the quick release option. Here are the sizes of each. Givi 41 (22"L x 17"H x 11"D ) Aero ABS Sidecase system (23"L x 15.5"H x 9"D )
Post by edvb on Apr 14, 2013 17:56:48 GMT
Ok, I did some more measuring and think I will order the Aero ABS Sidecase system. They seem to fit and look the best overall.
Thanks Scott for your input on this.
Post by roger32849 on Apr 14, 2013 18:06:16 GMT
Ed: The angled cut would ad a nice departure to the rounded curves of the front end chassis, but to make sure, you may want to draw a rounded template and place it over the front. There isn't a ton of ways to cut a fender. I like the rounded front end, like the old Honda's and Yamaha's. I have set of Hondaline square bags that I was going to experiment with. After looking at the Givi E41 it may be a better option. I noticed the E41 lines are similar to the chassis, curved and bowed. What is the distance between the exhaust and the bottom of the bag?
It all looks good, the fenders will look especially nice after they are coated and braced. You will be riding in high style this summer and with the bags attached the sky is the limit where you can go. Thanks for the updates and I will be looking for the pictures..
Roger
