Post by Paul (madeye) on Mar 30, 2013 9:45:28 GMT
i took ages and was really happy, i wanted to bolt through so it was another secure clamped point. all that work and i hacked it out and was pi$$ed off. hope you manage to keep it mate
Post by airforceone on Mar 30, 2013 12:38:56 GMT
I tried to cut out the panel for the cylinders at first but as Paul said, as soon as you have to adjust anything or remove that panel to get access to the steering column it is a PITA.
I would just cut that corner out. Even with the corner out it's still very secure and rigid.
Ned
Post by Deleted on Mar 30, 2013 13:37:37 GMT
IMHO, if I was relying on the panel to support the steering linkage with a bearing, then I'd bolt through. If your supporting the steering rod via a chassis mounted method, hack away my friend. Tbh, I'm never fond of extra sandwich layers between essential components, that's my own personal preference though.
Post by airforceone on Mar 30, 2013 14:01:59 GMT
Totally agree Steve.
Why cause yourself extra grief when there's already enough just building the thing.
Post by huggy on Mar 30, 2013 22:38:22 GMT
Food for thought. Cheers guys.
Post by huggy on Apr 6, 2013 21:48:15 GMT
Loose fit of wishbones, springs and dampers. Front. Rear.
Post by huggy on May 9, 2013 20:24:58 GMT
A few more updates (in no particular order): Front hubs fitted and torqued. Discs positioned ready to space callipers. Spacing requirement turned out to be 12mm as per a number of other builds.
Post by huggy on May 9, 2013 20:30:21 GMT
Gently bend radiator bottom mount extensions (idea derived from "Jack and Dad's" seat bracket bending) Tweaked brackets in place
Post by huggy on May 9, 2013 20:34:42 GMT
More panel work in progress ...and first cuts made on the steering side
Post by huggy on May 9, 2013 20:36:31 GMT
Another delivery :-)
Post by huggy on May 9, 2013 20:39:21 GMT
Position & mark rear wing stays ... holes drilled.
Post by BobN on May 10, 2013 8:37:45 GMT
Good progress dude, you'll get her rolling in no time. Its nice to get new wheels.
Post by huggy on May 10, 2013 23:42:15 GMT
Cheers Bob, I hope so :-)
Post by huggy on May 19, 2013 20:36:05 GMT
A few more steps taken: Bulkhead covered and trim fitted. Sides covered too (...have to 'carefully' trim/adjust later on as the bump steer checks showed I needed a little more packing than I expected. Oh well, not a problem).
Post by huggy on May 19, 2013 20:38:48 GMT
Bulkhead and pedals fitted.
