Post by John B on Jul 21, 2012 21:05:07 GMT
For what its worth I have one of those 'cheaper' stainless manifolds and it all lines up just as it should. If you could ask your mechanic friend what needs to be done to remove the EGR valve and pipe that would be good.
trident
Improvise, Adapt and Overcome
Post by trident on Jul 21, 2012 21:21:50 GMT
John
No problem I sort something .... with your exhaust are all the manifold pipes the same lenght to the first conection joint.
Chris
Post by John B on Jul 21, 2012 21:24:31 GMT
I'll have a look tomorrow when I'm next in the garage.
trident
Post by trident on Jul 21, 2012 21:37:09 GMT
Also any chance of adding a photo of your exhaut as the one's on ebay are not the best... Cheers
Post by John B on Jul 21, 2012 21:44:09 GMT
Will do, no problem.
trident
Post by trident on Jul 25, 2012 15:02:24 GMT
OK removed the EGR valve today.... Very simple job. First - just fully remove the pipe. I've kept the nuts and will make a blanking plate out of a small piece of alluminium using the end of the pipe as a pattern. Next you just remove the EGR Valve and vacum system. Just two bolts. Again I'll just make a small blanking plate and get some new shorter bolts. Again I'll just make a small blanking plate and get some new shorter bolts. Finally I just need to get some rubber caps to blank off where the rubber vacum hoses is connected ( Pipe with blue dashes on it ) and its job done. The valve and electrics all removed. John as you have stated your exhaust fits very well, can you please tell me which seller you got it from as I need one ;D Cheers Chris
Post by John B on Jul 25, 2012 15:17:25 GMT
Hi Chris, Sorry I haven't posted the pictures yet, been so busy!!! Any how I got my manifold from 1stcarparts on eBay. All I would suggest is if you buy one then check it as soon as it arrives. Cheers for posting the removal pictures, good work.
