mightylad
.....Mighty MEV Rocket.....
Post by mightylad on May 10, 2012 17:20:12 GMT
hi all,
I tried to keep it on two workmates for as long as possible... not very movable but the kit at the extra height off the ground helped with my dodgy back - i'm not good at bending over for long periods... if you know what I mean!!
as for the width i think it was a 9ft wide garage so access actually wasnt that bad... especially when i did get it on its wheels... Its best if you can work on it on the drive then wheel back in once done for the night...
Ol
Post by BobN on Feb 5, 2013 11:55:41 GMT
Hi Ol
I read in the tech section that you might have installed a mechanical brake switch instead of hydraulic one. Any chance you can post some pics? I have seen some on the forum already but just wanted more ideas.
Thanks Bob
mightylad
Post by mightylad on Feb 5, 2013 21:23:29 GMT
Hi bob... This is my setup.... I just bought a switch from RD and made a suitable bracket!.. Simples... Hope this helps Cheers Ol
Post by BobN on Feb 6, 2013 10:18:38 GMT
Awesome, thanks Ol !
This so far is the easiest solution and I will definitely be copying it.
By the way I did use your diagram to get a clutch adapter made by a friend at Jag, came out great but did not use it yet, plan to replace the clutch line in the summer with a braided line so will try it out then.
Bob
Post by testarossa on Feb 12, 2013 23:34:44 GMT
Another great built, like the engine and the black paintjob.
About the mechanical brake switch, you could also use the rear brake switch of a motorcycle. They are very easy to come by and are pull actuated, mostly via a spring (which makes mounting the sensor even more simple).
mightylad
Post by mightylad on Sept 12, 2013 18:44:49 GMT
All, I know this is a bit of an old thread now, but a couple of people have asked me to put up some pictures of the completed car... Well it would be rude not to really Several thousand miles now completed.. Very very happy with the Rocket... Building it seems such a long time ago - definitely worth all the pain though - it still puts a massive grin on my face every time I take it out! Ol
Post by mabbs on Sept 12, 2013 20:00:16 GMT
That made me smile Best post I have read on hear for a while. Keep it positive and great to hear you are enjoying life with the Rocket. ATB Jon
Post by sandancer73 on Sept 16, 2013 11:30:54 GMT
Nice pictures Ol, good to hear your still enjoying the Rocket.
Love the Black n White combo, fits really well with my Magpie (Newcastle United) following......
Post by minuit on Sept 18, 2013 3:50:08 GMT
Thanks for posting the completed pics; colors look great
Post by jake on Sept 18, 2013 11:18:56 GMT
Hi Mightylad,
What are those seats you have in your rocket?
Jake
mightylad
Post by mightylad on Feb 11, 2017 13:52:46 GMT
Hi, the Rocket is now up for sale... Check out the 'for sale' area on the forum.
