blobnnob
Junior
Dex at Curborough 2011
Post by blobnnob on Nov 24, 2011 16:47:19 GMT
Your problem doesn't seem the be the bushings, but more of the shock/spring combo. You need a stiffer spring, higher ride height, or both. Your best bet probably is the Raceland setup. It will have stiffer springs and fully adjustable ride height. Yes I think your right, sounds just the job. Is it a difficult job have you any tips. Been looking at Raceland but can only see Mk2 at the moment, I'll have to look again. Plan to start end December when we will sorn it, but at the moment with the mild weather still getting out every weekend ;D REgards Jeff
Post by Deleted on Nov 24, 2011 17:53:40 GMT
The raceland shocks don't come with any top mounts, I stuck the mk1 top mounts on with a couple of washers and it worked fine. The other option is to buy some mk2 top mounts from autolink or eBay. They have the same bolt pattern to fix to the Mev. Alex
blobnnob
Junior
Post by blobnnob on Nov 25, 2011 9:47:36 GMT
The raceland shocks don't come with any top mounts, I stuck the mk1 top mounts on with a couple of washers and it worked fine. The other option is to buy some mk2 top mounts from autolink or eBay. They have the same bolt pattern to fix to the Mev. Alex Thanks Alex, am I right in thinking that you used the mk2 shocks from Raceland were there any other probs? Jeff
Post by Deleted on Nov 25, 2011 10:31:49 GMT
Yep, used the mk2 shocks on a mk1 based kit. The only difference is the top mount, mk2 is slightly taller than a mk1 so I added a few thick washers to the end/top of the damper rod and it worked a treat with the mk1 mounts. You may have to shave a small slither off the inside edge of the top front wishbone as the race land shocks are much thicker.
blobnnob
Junior
Post by blobnnob on Nov 26, 2011 10:12:03 GMT
Thanks Alex, thats a great help. We are also going to rebush as our winter refurb project, think we'll order a kit with Freakyparts, not looking forward to this as we think everything is siezed up on the near side. ps. did the shocks come with bushes?
Thanks again, Jeff
