Post by Andy Patey on Feb 27, 2010 18:57:50 GMT
Hi ok i'll hope to get som wheels som time soon . keep up the good work
Post by r16 on Feb 27, 2010 19:25:24 GMT
my 1st choice was oz super or ultra laggeras but they are very costly but very light :-) momo was my second choice and to be honest they are close to the weight of the superlaggeras and you can get them at amuch better price.
Post by r16 on Mar 12, 2010 19:28:19 GMT
short video of the cars first test drive... you can see how heavy the steering was before i fixed it ;D
Post by r16 on Mar 12, 2010 19:37:37 GMT
Post by r16 on Mar 12, 2010 19:52:24 GMT
welding and wrapping was done on the bench (no comments about the mess on my workshop floor)
Post by r16 on Mar 12, 2010 19:53:23 GMT
Post by r16 on Mar 12, 2010 19:56:03 GMT
got to start them young!...
Post by r16 on Mar 17, 2010 21:12:59 GMT
Post by r16 on Mar 17, 2010 21:27:13 GMT
Post by Scott on Mar 18, 2010 8:54:46 GMT
Phil,
Looks good, If its a bit bit at the bottom can you spread the tunnel slightly at the bottom to make it fit before you bolt it down???
Scott
Post by r16 on Mar 18, 2010 18:11:47 GMT
thanks scott, i might do that but will also add rubber trip as all the other pannels have rubber trim on them and i want it to match.
Post by Andy Patey on Apr 5, 2010 21:12:57 GMT
Hi the first run was f.....g great but I can only get into 3rd gear where I live to I wanted to go around the block but I have to Be careful because a copper lives in the close. the gears are all ok the brakes are ok and the motor is running nicely I have not got the water circulating rig yet but have to look at that next time. Andy
Post by r16 on Apr 7, 2010 16:32:57 GMT
made a little cover for the steering column and u j the other day, not bad for 1 hours work, and it looks ok i think... do we think iva man we be happy that it won't just "fall off" after the test??? bent a bit of ali i had left over from something else, held it in place to mark out and then cut the hole to fit over the rack... then covered it in the same sticky carbon sheet i used for the back pannels. clips hold the rubber trim in place as the polyurithane glue sets... its riveted to the car with 4mm rivets which fit well in the mesh pannel, if i ever take it off again there will be no holes/damage to the side pannel. thats it in place, just the engine mount covers to make now ;D
Post by Andy on Apr 14, 2010 14:42:07 GMT
Hi phil how's the engine mount covers coming along is the steering rack cover open at the front ? Looking good andy
Post by r16 on Apr 14, 2010 18:22:46 GMT
hey mate,
yes its open at the front, with a bit of luck it will channel air to the mc's (though im not sure they need it)
engine mount covers are alot harder to make out of ali :-( iv not come up with anything that looks good yet :-(
