Post by rcnut on Nov 14, 2009 16:43:47 GMT
Hi hopefully not to technical. Has anyone tried to fit newer calipers to the sonic rear uprights,holes don't line up. I was thinking of moving holes to accommodate,both holes in 4mm,what do you think? Have new handbrake cables to fit so don't really want to change to older calipers that have a different fitting.
Post by r16 on Nov 14, 2009 17:28:22 GMT
i looked at fitting the newer calipers to my rocket... the holes are off but i also found fitting the discs to be a problem to. if you have the discs put them one and you will see what i mean.
Post by dinosaurjuice on Nov 14, 2009 18:32:42 GMT
im using mk3 focus rear calipers.
avoid!
you will need to make new caliper mounts to allow for a different disc offset. and even if you get them mounted the handbrake cables go off in a not ideal direction.
i would recommend going to local scrappy and buying the older calipers which bolt straight on, no hassle.
will
Post by r16 on Nov 14, 2009 19:34:55 GMT
i have one (n/s i think) you can have for £10 plus postage :-)
Post by rcnut on Nov 15, 2009 14:14:25 GMT
Thanks for the response,I will probably go the older way. Thought I had everything sorted before getting my kit,oh how wrong I was. Second day into build and bugger it. Need following things: Adapter to connect rack to focus. Different track rod ends. Different calipers/ handbrake cable. And thats just for starters. Though the floor is sealed and riveted.I will have to study the build manual very closely before making further purchases which are a waste of time???
Post by r16 on Nov 19, 2009 16:50:10 GMT
the problem is you never know what you need untill you need it, im almost finished and im still finding little things that i need.
