Post by latemarch on Jul 14, 2011 1:32:53 GMT
If you don't have a reverse solution then you need some way to stop the vehicle when you are outside of it pushing it around. A hand brake somewhere near the steering wheel would be handy.
Post by edwinwl on Jul 14, 2011 16:25:26 GMT
I agree: Handbrake is handy but not striktly neccesary.
(Engine turned of and gearbox in first gear does the same.)
vtR1k
I'm a trike lover...
Post by vtR1k on Jul 14, 2011 19:27:00 GMT
Well, in the Netherlands it's mandatory...
Post by edwinwl on Jul 15, 2011 17:19:34 GMT
This afternoon made a battery-stand: Sorted out more wiring: Installed the start motor back in with new wiring:
Post by edwinwl on Jul 16, 2011 18:45:50 GMT
This afternoon progress: Steering colomn ready: Rear hand brake capiler: Hand brake handle (only 1 of 2 brakets is ready): Hand brake in place:
vtR1k
Post by vtR1k on Jul 18, 2011 9:59:52 GMT
Do you think you have enough space for the cooling pipes?
Post by edwinwl on Jul 18, 2011 11:39:28 GMT
There should be enough space... Today my items arrived to mount the cooling pipes. The test of the pudding is in the eating. :-)
And the centre tunnel has to go up, where the gearlever and hand brake handle are.
Post by edwinwl on Jul 23, 2011 21:02:47 GMT
Today was more plumbing, work on handbrake, center tunnel and I made a heat hield. (The fuel tank, right on the picture, is cleaned and polished...
Post by fuoriserie on Aug 1, 2011 13:11:08 GMT
Nice build pictures
Post by edwinwl on Sept 11, 2011 19:58:35 GMT
Back from holiday and finally some time to continue my build. Ordered a swirl pot: Bolted it on the car and connected the fuel lines: Extra fuel pump and filter: Bulk head cut out and new parking brake support (version 2):
Post by edwinwl on Sept 18, 2011 13:41:59 GMT
Cable loom plan: Bought 7 wire trailer cable with PUR mantle: Motor Management 1 7x 1,5mm Motor Management 2 7x 0,75 Fuel Pumps & Ignition 7x 0,75mm Rear Light 7x 1,5mm Function Original wire color Cable New wire color Throttle position (16) Black / blue MM1 Black Yellow MM2 Yellow Blue MM2 Brown Speed sensor (22) White MM2 White Bleu/yellow MM2 Bleu Black/Blue MM1 Black Exup (15) White/Red MM1 Brown Bleu MM2 Brown Black/Blue MM1 Black Black/Red MM2 Red Black/Yellow MM2 black Neutral (21) Bleu MM1 Bleu Oil Level (55) White MM1 Red Pick up coil (20) Grey MM2 Green Black/Blue MM1 Black Generator (3) White1 MM1 White White2 MM1 Yellow White3 MM1 Green Fuel Pump (12) Black FPI Black Black/Blue FPI Bleu Swirl pot fuel pump Red FPI White Black FPI Brown Ignition Coil (18) Red FPI Red Orange FPI Yellow Grey FPI Green
vtR1k
Post by vtR1k on Sept 18, 2011 17:51:14 GMT
lot of work huh? I Know... :-)
Post by edwinwl on Sept 18, 2011 19:29:00 GMT
All day....
Post by edwinwl on Oct 1, 2011 17:26:42 GMT
Today fitted the throttle cable: EXUP servo: And started with the exhaust. Lower mount is in place.
Post by Deleted on Oct 1, 2011 21:05:34 GMT
Excellent progress...
