Post by keithb45 on Jun 14, 2019 12:35:41 GMT
Hello Can anyone advise? Have reached the switch on stage having modified the mx5 loom and virtually nothing works.Front headlights and 1 amber realright only and they come on as soon as battery is connected Trying to find electrician to help Any pearls of wisdom would be great fully received.
Post by lemans75 on Jun 14, 2019 22:35:27 GMT
I had some gremlins that ended up being related to the black ground wires that go to a set of plastic blocks. The wires were corroded inside the plastic sleeve (making it hard to detect). Scroll though page 5 and you'll see what I mean: mevowners.proboards.com/thread/9813/boston-build?page=5Another thing to check is the fuse block with all the tiny fuses. I found that a bunch of them had burned out, most likely from from my mucking around with wires and shorting them out.
Post by keithb45 on Jun 16, 2019 13:50:07 GMT
Post by keithb45 on Jun 16, 2019 13:51:07 GMT
I had some gremlins that ended up being related to the black ground wires that go to a set of plastic blocks. The wires were corroded inside the plastic sleeve (making it hard to detect). Scroll though page 5 and you'll see what I mean: mevowners.proboards.com/thread/9813/boston-build?page=5Another thing to check is the fuse block with all the tiny fuses. I found that a bunch of them had burned out, most likely from from my mucking around with wires and shorting them out. [b Thanks for information. I appreciate it .
Post by keithb45 on Jun 16, 2019 15:45:24 GMT
I had some gremlins that ended up being related to the black ground wires that go to a set of plastic blocks. The wires were corroded inside the plastic sleeve (making it hard to detect). Scroll though page 5 and you'll see what I mean: mevowners.proboards.com/thread/9813/boston-build?page=5Another thing to check is the fuse block with all the tiny fuses. I found that a bunch of them had burned out, most likely from from my mucking around with wires and shorting them out. Thanks very much for the reply and all the time and effort to do it. I will study and do the best given the info Keith
